GregMcMahon
Matched pair analysis with categorical responses
Hello everyone,
This will be straightforward I'm sure. I have 100 rows of data representing individuals. The two columns are binned percentages (0-10%, 11-20% etc.), one for two different years. If the responses were numeric, the matched pair analysis would be exactly what I want. But the responses are categorical so that is out.
Any suggestions are greatly appreciated!
Best regards,
Greg
GregMcMahon
Re: Matched pair analysis with categorical responses
Just one other thing to add - it looks like the Agreement statistic may be what I'm after, except I'm more interested in the change and if it is trending up or down.
Agreement between ordinal variables is like correlation between quantitative variables.
The Cochran Armitage test might be helpful to you, too.
GregMcMahon
Thank you Mark!
GregMcMahon
Hi Mark,
For the Cochran-Armitage, are you  suggesting I recode the percentage bins to 1,2,3..and make it an ordinal scale?
Thanks again,
Greg
I thought it was already ordinal. The bins as you originally described are find, just change the modeling type to ordinal and make sure that the value orders are correct. If they are not correct, then add the Value Order column property and specify the correct order.
