Match columns on table update using string
I'm trying to update one data table with columns from another table, using matching columns criteria defined by a string.
In the example below, dt1 is my main table, and dt2 is a sort of config file containing the column to add (i.e. "ROUTE"), while all other columns are used in matching to dt1. Since dt2 is user-defined, I can't know these other column names ahead of time, hence the need to use a formatted string:
// define string for column matching
textinp = "";
matchCols = dt2 << get column names(string);
// remove "ROUTE" from dt2 column name list
for (i = nitems(matchCols), i > 0, i--,
    if (contains(matchCols, "ROUTE"), remove from(matchCols, i));
// create string for column matching
for (i=1, i<=nitems(matchCols), i++,
  textinp = concat(textinp,":",matchCols," = :",matchCols,", ");
textinp = left(textinp,length(textinp)-2);
print(textinp);
// update dt1
dt1 << Update(
  With( dt2 ),
  Match Columns(
  parse(textinp)
Parsing textinp to the update command produces this error (the string is produced correctly as seen in the first line):
":X = :X, :Y = :Y"
Unexpected ",". Perhaps there is a missing ";" or ",".
Line 1 Column 8: :X = :X►, :Y = :Y
As far as I know there shouldn't be any problem separating multiple columns with commas inside match columns(), and in fact when I try to define it literally, i.e.:
// update dt1
dt1 << Update(
  With( dt2 ),
  Match Columns(
  :X = :X, :Y = :Y
It works perfectly fine. Any idea why it can't handle / parse the string? Your help is greatly appreciated!
ms
Super User (Alumni) ms
Re: Match columns on table update using string
Match Columns() apparently accepts two lists of column names (not as strings) as its matching argument.
Try this:
// Example tables
dt2 = Open("$SAMPLE_DATA/Big Class.jmp");
dt1 = dt2 << subset(selected columns(0), sampling rate(0.5));
dt1 << delete columns(name);
// define list for column matching
matchCols = dt2 << get column names();
Remove From(matchCols, Contains(matchCols, Expr(name)));
// update dt1
dt1 << Update(With(dt2), Match Columns(matchCols = matchCols));
pmroz
This should work:
update_expr = evalinsert(
"dt1 << Update(
With( dt2 ),
Match Columns(^textinp^)
eval(parse(update_expr));
ms
Try this:
// Example tables
// update dt1
Thank you both! Only tried the 2nd answer, which worked!
