ileshem
Community Trekker
Make a variable from and average of selected rows in a column to use later as a reference line.
I want your help with finding an average of selected row in a column and use it as a reference line in a graph.
I have a data table:
A
12.5
B
13.4
B
17.5
B
12.8
A
11.1
A
19.4
B
13.8
 I want to make a variable that is an average of all the “B” line values ((13.4+17.5+12.8+13.8)/4) in the example above.
Then I am going to use it as a reference line in a Bivariate graph.
dale_lehman
Community Trekker
Re: Make a variable from and average of selected rows in a column to use later as a reference line.
If I am understanding what you want correctly, try creating a new variable using the Col Mean function with your first column as a "By" variable.  Then create another column with an IF statement that uses the B mean value for both groups A and B.  That column will then all have the same value = mean of the group B values.
uday_guntupalli
Community Trekker
@ileshem ,
  Once the data table is openend , select random rows . You can do this by :
Rows > Row Selection > Select Randomly
AgeVals = :age << Get Values ; // Get Values in Age Column
SR = dt << Get Selected Rows(); // Get Selected Rows
RequiredVar = AgeVals[SR,0]; // Desired Values subset from Column Values
Best
Uday
ileshem
Community Trekker
Thanks for the prompt replay,
I was able to create a new table with the rows I wanted, but I am not sure how to calculate the MEAN of that column (VALUE) into a variable.
my_list = {"B"};
dtsub1 = dtEPData << subset(
rows( dtEPData << get rows where( Contains( my_list, :TYPE ) ) ),
Selected columns only( 0 ));
TYPE VALUE
A 12.5
B 13.4
B 17.5
B 12.8
A 11.1
A 19.4
B 13.8
Dtsub1=
TYPE VALUE
B 13.4
B 17.5
B 12.8
B 13.8
uday_guntupalli
Community Trekker
@ileshem ,
Col Mean() - if you want to use the column
Mean() - if you want to use the matrix or a separate variable
dt << Select Randomly( 0.3 );
dt1 = dt << Subset(Selected Rows( 1 ), selected columns( 0 ));
Res = Col Mean(dt1:age);
Show(Res);
Best
Uday
dale_lehman
Community Trekker
