Neo
Neo
Make Filter Change Handler () triggering only after second filter change, why not first?
I use the Make Filter Change Handler () to dynamically change the y-axis title based on changes made by the user on the local data filter. The script uses solution by @hogi from here. However, in my example case (script below) which represents my actual case closely, the y-axis title is changes only after the second checkbox is checked on "age". How to make the y-axis tile change upon the first age selection (I am on JMP 16.2.0)?
gb = Graph Builder(
	Size( 855, 687 ),
	Show Control Panel( 0 ),
	Variables( X( :name ), Y( :age ), Group Y( :height ) ),
	Elements( Points( X, Y, Legend( 37 ) ) ),
	Local Data Filter(
		Conditional,
		Add Filter(
			columns( :sex, :age ),
			Where( :sex == "F" ),
			Display( :sex, "Check Box Display" ),
			Display( :age, "Check Box Display" )
	Dispatch( {}, "graph title", TextEditBox, {Set Text( "" )} ),
	Dispatch( {}, "Y title", TextEditBox, {Rotate Text( "Left" )} )
ldf = Current Report()["Local Data Filter"] << get scriptable object;
changeTitle = Function( {this},
	print(this);
	ldfText = Regex(ldf << get where clause(),"\( *(:age == .*?)\)","\1");
	if(ismissing(ldfText),ldfText = "all ages");
	(Report( gb ) << XPath( "//TextEditBox" ))[4] << Set Text( ldfText );
fsh = ldf << Make Filter Change Handler(
	changeTitle();
When it's too good to be true, it's neither
Re: Make Filter Change Handler () triggering only after second filter change, why not first?
The regex being used doesn't work if there is only one age selected and it will result in "all ages".
Where clause when only one age is selected
"Select Where(:sex == \!"F\!" & :age == 15)"
Where clause when more than one ages are selected:
"Select Where(:sex == \!"F\!" & (:age == 14 | :age == 15))"
You will have to make slight modifications to the regex pattern
Edit:
Something like this might work https://regex101.com/r/Z6pg9N/1
Neo
Neo
@jthi The following appears to work for my example case above
ldfText = Regex(ldf << get where clause(),"\(?\s*(:age == .*?)\)","\1");
However, for my actual case, the above script change works only when the default selected checkboxes by the Add Filter () inside Graph Builder() are first unchecked and then rechecked. Once it stats working, all if fine. What could be wrong?
Most likely the first filter state is ran before filter state handler is even added. You could call changeTitle() with a reference to the local data filter to make sure the function is run once after graph has been created
gb = Graph Builder(
	Size( 855, 687 ),
	Local Data Filter(
		Conditional,
		Add Filter(
			Where(:age == 12),
	print(this);
changeTitle(ldf); // to run the changeTitle() function once
	changeTitle();
Neo
Neo
@jthi . Calling Change Title () as your script did not change anything. Unfortunately I cannot share my actual script (:.
Note the first time selection shows all the checked filters on the y-axis. Perhaps this may provide a hint as to what is going on.
Unchecking all checkboxes and checking them back as desired produces the expected result.
Any suggestions will be very useful.
No idea. You will have to create some sort of mock-up which is able to replicate the issue to make debugging easier
