Uribo
Loop(FOR) / basic
Dear Masters,
Nice to meet you.
I tried to double loop with the script , attached csv data but it will not be the result I think.
The minimum value of the difference between the A column and B 1, the minimum value of the difference between the A column and B 2, the minimum value of the difference between the A column and B 3,........difference between column A and B10.
I wanted to output the minimum value of the difference between column A and B until B10, but only the minimum value of difference between A1 and B1, value was "-8", is output.
db = Current Data Table();
temp = Column( "A" ) << Get Values;
temp2 = Column( "B" )<< Get Values;
Row = N Row( db );
a=0;
For( i = 1,Row, i++,
a=temp[i];
g=0
For( j = 1, Row, j++,
g = temp2[j];
Col Minimum(a-g );
Thank you for your kind support.
Uribo
Re: Loop(FOR) / basic
You have 2 issues of syntax.
1. The For() loop requires the termination expression to be a comparison of some sort.
2. You have specified a column called "A" and a memory variable called "a".  Because you did not show any scoping to indicate that the variable "a" is to be treated as a memory variable, JMP assumed you were referring to the column "A".  Remember, JMP is not case specific.
Here is a corrected version of your script
temp2 = Column( "B" ) << Get Values;
Row = N Row( db );
::a = 0;
For( i = 1, i <= Row, i++,
	::a = temp[i];
	g = 0;
	For( j = 1, j <= Row, j++,
		g = temp2[j];
		Col Minimum( a - g );
Row = N Row( db );
::a = 0;
	::a = temp[i];
	g = 0;
		g = temp2[j];
Uribo
Dear txnelson,
Thank you very much for your quick reply, and polite commentary .
I was saved because the JMP script was at a loss as a novice beginner.
Regars,
Uribo
