nguyendv0610
Load Factors table into DOE using JSL
I am designing multiple DOE using risks assesments done in Excel. I wrote a script to organize all the variables into a neat table and converted the properties to that of a factors table (credit to a previous post (Saving a data table as a factors table:(
dt3  = Current Data Table();
nomdata = dt3 << get column names( nominal );
condata = dt3 << get column names( continuous );
For( i = 1, i <= N Items( nomdata ), i++,
  Column( dt3, Char( nomdata[i] ) ) << Set Property("Design Role", Design Role( Categorical ), Factor Changes( Easy))
For( i = 1, i <= N Items( condata ), i++,
  Column( dt3, Char( condata[i] ) ) << Set Property("Design Role", Design Role( Continuous ),  Factor Changes( Easy))
Now I would like load this factot table into the Custom design DOE, is there a way to do this using JSL or is using the graphic interface the only way?
nguyendv0610
Re: Load Factors table into DOE using JSL
I solved it. It was actually a super simple solution:
DOeInit = DOE(
	Custom Design,
	{Add Response( Maximize, "Y", ., ., . ), Set Random Seed( 4547922 ),
	Optimality Criterion( Name( "Make D-Optimal Design" ) ), Simulate Responses( 0 ),
	Save X Matrix( 0 )}
DOeInit << Load Factors()
As long as the Factors table remain open, this will automatically gets imported.
nguyendv0610
DOeInit = DOE(
	Custom Design,
	Save X Matrix( 0 )}
