therese
Linear modeling - log transformed/square root transformed Y-variable
Hi all JMP users,
Does anyone know how to do this in JMP? I want to do a normal linear modeling where the log is transformed or with a square root transformed Y-variable.
Thank you!
Re: Linear modeling - log transformed/square root transformed Y-variable
When you go to choose the Y column in the Fit Model, or any other of the JMP Platforms, you can right click on the column you want to use for the Y variable, and select the transform form you want to use
You can also select the response in the Y role and then click the red triangle next to Transform in the middle of the dialog  box, just to the left of the Effects list.
