Linear modeling - log transformed/square root transformed Y-variable
Sep 24, 2018 06:23 AM(9848 views)
Hi all JMP users,
Does anyone know how to do this in JMP? I want to do a normal linear modeling where the log is transformed or with a square root transformed Y-variable.
When you go to choose the Y column in the Fit Model, or any other of the JMP Platforms, you can right click on the column you want to use for the Y variable, and select the transform form you want to use
You can also select the response in the Y role and then click the red triangle next to Transform in the middle of the dialog box, just to the left of the Effects list.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '75441' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '75441') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '75441') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
