hmurrayiv
Limiting regression line to range of data
I am using the Bivariate fit platform to plot regression lines for a spec from different batches over time. Some of the batches have time points (x-axis) that are longer than other batches. When I use group by (batch) and then fit line, I get individual regression reports and confidence intervals for each batch. The problem I have is that the regression lines for the batches with time points that to go as long as others have the regression line extrapolated out way past the last time point I have for that batch.
When I use graph builder, the regression lines for each batch only extend to the last data point. Is there anyway I can have my lines in that style for the Bivariate fit platform?
Thank you
Phil_Kay
Re: Limiting regression line to range of data
I don't think there is any option to change the range over which the fit lines extend. Maybe one for the Wish List.
If you explain more about the objectives of your analysis, someone might be able to help with another solution.
Regards,
Phil
