mvanderaa1
Life distribution line properties cannot be changed (JMP17 related?)
I just started using JMP 17 (not sure this is related), but in some instances I can not change any properties of the lines in the life distribution platform.
I attached my datatable with a script to generate a weibull plot. Note that I'm initially changing the colors in the script to reflect the row states, which apparently works. but once the platform is open I cannot change anything anymore. In the script I already try to set the line width to 3, but this also doesn't work (this did work with this script in JMP16.2).
10 REPLIES 10
peng_liu
Re: Life distribution line properties cannot be changed (JMP17 related?)
In JMP16, the legend that you see cannot control line width. It has very limited functions.
