TDun
Life and Survival dataset
I am looking at a component within our product that is on 10000+ products in the field. Should I only be looking at failures? I have the ability to include all the products that have never had this component fail. Is it best to include those in the dataset, or should I only be looking at failures?
peng_liu
Re: Life and Survival dataset
Answer should depend on the details of your data and objectives.
Here is one scenario:
If your data is like what are in this example: Example of the Life Distribution Platform and the objective is to estimate failure probability like in the example, excluding products that have not failed will severely mislead you.
