Anne_S
Levey Jennings chart restart subgroup labels
Dear Support Team,
I'm working with Levey Jennings Control Charts and would like the subgroups plotted on the X axis to restart at 1 for each phase. How can I do this (interactive explanation preferred)?
Many thanks in advance
Anne
Re: Levey Jennings chart restart subgroup labels
You need a data column for the phase, subgroup, and data. Like this:
Then select Analyze > Quality and Process > Control Chart > Levey Jennings Control Chart. Assign the data columns to the appropriate analysis role. Like this:
(Note: this chart can be made interactively with Control Chart Builder instead of using a dialog, so you can pick your preferred method.)
You should get this result in Control Chart Builder when you click OK:
(Note: You can apply limits or sigma from an external source instead of JMP computing the limits from the data in the plot, which is generally the case for these charts, after the CCB opens using interactive commands.)
Anne_S
Hi Mark,
it worked (& was a fairly obvious solution, I admit).
My problem was that we haven't yet fully upgraded to JMP 16, and in 15 this option didn't exist... So thanks for adding it, it's coming in useful already.
Best regards
Anne
