LABLE VALUES IN A GRAPH BUILDER
In this moment i have JMP10, how can i see the values in my graph builder??
I have already " label" the column in my data sheet, in fact it is signed with an asterisk in my data table. But when i put this column in my graph builder, i don't see any values.
Thierry_S
Re: LABLE VALUES IN A GRAPH BUILDER
I am not completely sure that I understand your issue but one possible fix (assuming it is available in JMP 10) is to go the bottom left of the Graph Builder window, select the "Label" entry and select "Label by Rows".
Let us know if that works for you.
Best,
TS
Thierry R. Sornasse
