Revels2305
Key Driver Analysis Help
So trying to run a key driver on market research data, started by using the fit X to Y and specifying Y as the dependant variable. I've got 4 other independent variables with scales of 0-10. I've used "Fit Line" to run the linear regression but don't know where to go from there
Re: Key Driver Analysis Help
This free course might be what you're looking for: Statistical Decisions with ANOVA and Regression - JMP User Community
Revels2305
Perfect thank you
