Hi all,
Assume that I have two columns, Bob and Mary, who rate four items with either a Y or a N. In the following case, no Agreement Statistic is present when doing Fit Y by X, because it appears that JMP thinks that Bob and Mary do not have the same categorical levels. How can I set column "Bob" to inform JMP that Bob can also take on values or Y or N? For example, if I change one of the columns in Bob to N, the Agreement Statistic feature is available again.
![6287_2014-05-12_20-32-34.png 6287_2014-05-12_20-32-34.png](https://community.jmp.com/t5/image/serverpage/image-id/372i400BB3DFAC8D6ECB/image-size/medium?v=v2&px=400)
I feel like this should be specified in Column Properties somewhere, but I can't figure out how to make it work.
