joshua
Jsl error when reading excel file that is open by excel :: There was an error opening the file.
I was wondering any work around this. The case is I have my windows and excel file is open that I edit and save. Meanwhile, I try to open that excel file with jsl for further data processing (the *.xlsx still open with Excel while I'm doing this.)
When I try to open that file I get this error
              "There was an error opening the file."
Is there any work around this ? This excel file is shared excel file so it's most likely would be open by another user and another computer so I hope jsl has solution to work around this ?
I am using JMP 14.0.3
Thanks
frank_wang
回复: Jsl error when reading excel file that is open by excel :: There was an error opening the file.
Open(
	"D:\ATS\frankwang\Desktop\Test.xlsx", // Here is file path
	Worksheets( "Sheet1" ), // Worksheets Name
	Use for all sheets( 1 ), // Check seting use for all sheets or not (1 -> Y, 0 -> N)
	Concatenate Worksheets( 0 ), // Check need concatenate work sheets or not
	Create Concatenation Column( 0 ), // if you want to concate, this will be set
//Below setting about Data Table of sheet. Such as Column Header, Number of rows in hearder and so on
Worksheet Settings( 1, Has Column Headers( 1 ), Number of Rows in Headers( 1 ), Headers Start on Row( 1 ), Data Starts on Row( 2 ), Data Starts on Column( 1 ), Data Ends on Row( 0 ), Data Ends on Column( 0 ), Replicated Spanned Rows( 1 ), Replicated Spanned Headers( 0 ), Suppress Hidden Rows( 1 ), Suppress Hidden Columns( 1 ), Suppress Empty Columns( 1 ), Treat as Hierarchy( 0 ), Multiple Series Stack( 0 ), Import Cell Colors( 0 ), Limit Column Detect( 0 ), Column Separator String( "-" ) ) )
For detail, can check in Index Script and search 'Open'
心若止水
ih
Super User (Alumni) ih
Re: Jsl error when reading excel file that is open by excel :: There was an error opening the file.
Hi @joshua,
You could copy the file to a temporary location and open it from there.
Names default to here(1);
fn = "$Sample_Import_Data/Bigclass.xlsx";
tfn = "$TEMP/tempfile.xlsx";
copy file(fn, tfn); Open( tfn, Worksheets( "Bigclass" ), Use for all sheets( 1 ), Concatenate Worksheets( 0 ), Create Concatenation Column( 0 ), Worksheet Settings( 1, Has Column Headers( 1 ), Number of Rows in Headers( 1 ), Headers Start on Row( 1 ), Data Starts on Row( 2 ), Data Starts on Column( 1 ), Data Ends on Row( 0 ), Data Ends on Column( 0 ), Replicated Spanned Rows( 1 ), Replicated Spanned Headers( 0 ), Suppress Hidden Rows( 1 ), Suppress Hidden Columns( 1 ), Suppress Empty Columns( 1 ), Treat as Hierarchy( 0 ), Multiple Series Stack( 0 ), Import Cell Colors( 0 ), Limit Column Detect( 0 ), Column Separator String( "-" ) ) ); delete file(tfn);
hogi
Level XIII
Is there an option to check if the file is opened in Excel ?
Is there an option to load the Excel file in a way in Jmp such that it's OK that the file is opened in Excel - e.g. with read only flag?
