AT
AT
Join two tables with variable names
I like to join two tables with variable names. Here is the script.
Eval(
	Parse(
		"s3 << Join(
With( rds),
Merge Same Name Columns,
By Matching Columns(
" || name3 || ",
" || name4 ||
Drop multiples( 0, 0 ),
Include Nonmatches( 1, 1 ),
Preserve main table order( 1 )
I get an error " Name Unresolved: Red LED Hue x 64{1} in access or evaluation of "Red LED Hue 64/*###*/. No issue with name3 "Serail#" but issue with "Red LED Hue x 64[1]".
Here is the scrip that works fine but I like to replace the variables names with name3 and name4.
Data Table( "S3" ) << Join(
	With( Data Table( "RDS" ) ),
	By Matching Columns( :Serial# = :Serial#, :Name( "Red LED Hue x 64[1]" ) = :Name( "Red LED Hue x 64[1]" ) ),
I appreciate your help.  Thanks
cwillden
Re: Join two tables with variable names
Oops, you're missing quotes inside of name.  Forgot about that.  You can do that several ways, but here's one where we use escape syntax to insert double quotes inside of a string.
name1 = ":Name(\!"" || xvar || "\!")";
name2 = ":Name(\!"" || yvar || "\!")";
name3 = name1 || " = " || name2;
You should definitely use the :Name("col name") approach to keep this robust since you will need it to handle situations with special characters in the column names.
-- Cameron Willden
6 REPLIES 6
cwillden
how are you defining name3 and name4?  Can you post that part of your script as well as show how those variables evaluate in the log? (e.g. run "Show(name3, name4)")
-- Cameron Willden
AT
AT
Thanks Cameron. The name3 and name4 are listed below when show(name) is invoked.
name3 = ":Serial# = :Serial#";
name4 = ":Red LED Hue x 64[1] = :Red LED Hue x 64[1]";
The name 3 and name4 are created by using the following script:xvar = .;
yvar = .;
win = New Window( "Choose Two Variables for Matching",
	<<Modal,
	<<On Validate(
// require the user to select two variables before clicking OK
		Show( xvar, yvar );
		If( Is Missing( xvar ) | Is Missing( yvar ),
			0, // if xvar or yvar are missing, do nothing when OK is clicked
			1
	Text Box( " Select two numeric columns. " ),
	H List Box(
		Text Box( " Choose First " ),
		x = Col List Box(
			dt1, // data table reference
			all, // display all columns from the data table
			xvar = (x << Get Selected)[1];
// get the name of the selected column before the window closes
			Show( xvar );
		Text Box( "Choose Second" ),
		y = Col List Box(
			dt2,
			all,
			yvar = (y << Get Selected)[1];
			Show( yvar );
xcol = Column( dt1, xvar ); // get the columns
ycol = Column( dt2, yvar );
name1 = ":" || xvar;
name2 = ":" || yvar;
Show( name3 );
Similarily for name4.
cwillden
The problem is almost certainly with the square brackets in Name4.  If column names have special characters, then you cannot use the colon(:) with the column name.  You need to get the column name string wrapped in :Name().
Try this:
name1 = ":Name(" || xvar || ")";
name2 = ":Name(" || yvar || ")";
-- Cameron Willden
AT
AT
Thanks Cameron. I modified name3 and name4 like what you suggested and I got an error:
Name arg must be quoted string
Line 5 Column 9:   :Name(►Serial#) = :Name(Serial#),
If I keep name3 like before, no error for Serial# but for name4. I don't know a priori what users chooses for name3 and name4.
Thanks for your continuous support.
cwillden
-- Cameron Willden
AT
AT
Thanks Cameron. I tried it and work fine. Thanks again.
