Jmp not recognizing the column headers from excel
I am trying to open an excel file from JMP to start analysis. This excel file has the column headers on row 1, but JMP is not able to detect the column names even after selecting the check mark on the import option and additionally, JMP only shows columns from 6 and doesn't read all the columns. First screenshot is jmp export page not detecting the column names. Second screenshot is the excel file that has column names. Can I know how to fix this import issue?  Thank you
10 REPLIES 10
StarfruitBob
Re: Jmp not recognizing the column headers from excel
If I understand your thread correctly, and you're using JMP 17, it might be related to this bug that was found.
https://community.jmp.com/t5/Discussions/Problem-Importing-Raw-Excel-Data-in-JMP-17/m-p/616405#M8160...
Learning every day!
