terapin
JSl Code to Delete Column Referenced By Formula
I'm trying to delete a column in JSL. However, the column to be deleted is used by another column in a formula. I can't find the syntax for JSL to remove the formula when I delete the column. Any ideas how to accomplish this would be appreciated.
Re: JSl Code to Delete Column Referenced By Formula
You should delete the formula referencing the column first:
Column("column name") << delete formula;
Then delete the column.
terapin
Thanks. That was rather simple and easy.
