CDW
CDW
JSL user defines row legend color
appreciated if someone can share the knowledge to define and assign row legend color.
take Cheese.jmp dataset example, if it is possible to assign row cheese A = pink color, cheese B= black color by using JMP 14.
Bivariate(
	Y( :Score ),
	X( :Count ),
		Dispatch(
			"Bivar Plot",
			FrameBox,
			{Row Legend(
				Cheese,
				Color( 1 ),
				Color Theme( "JMP Default" ),
				Marker( 0 ),
				Marker Theme( "" ),
				Continuous Scale( 0 ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
Re: JSL user defines row legend color
You can right click on the Legend grouping and select the color you want the row values to change to
Here is the chart with the A Cheese set to pint, and the B Cheese set to black
How I would do this in JSL would be:
For Each Row(
	If(
		:cheese == "A", theColor = "light red",
		:cheese == "B", theColor = "Black",
		:cheese == "C", theColor = "Orange",
		theColor = "Green"
	Row State( Row() ) = Color State( thecolor );
Bivariate(
	Y( :Score ),
	X( :Count )
Level XIII
Another approach:
via Value Colors property of the column.
I hope it was available in Jmp14?
Yes, Value Colors are available in JMP 14.
