The Discovery Summit 2025 Call for Content is open! Submit an abstract today to present at our premier analytics conference.
See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
View Original Published Thread
JSL to loop words in a list
mward
Hey guys,
I have a really basic JSL question, I hope.
I'm using this line to create a list of words in a string.
all_list = words(first_string, " ");
I then want to loop all the words in all_list and get rid of any words that are a length of three or less.
How do I set up that loop?
Thanks in advance!
Matt
ms
Super User (Alumni) ms
Re: JSL to loop words in a list
One approach is to use the Remove From() function in a reversed loop, i.e. removing items from the end of the list to preserve the list item numbering.
first_string =
"Change the scale of a plot by clicking in the frame with the Magnifier tool or by rescaling the axes";
all_list = Words( first_string, " " );
For( i = N Items( all_list ), i > 0, i--,
  If( Length( all_list[i] ) <= 3,
  Remove From( all_list, i, 1 )
Show( all_list );
ms
first_string =
Show( all_list );
nnk
nnk
Just trying to ask a related question....how can one save a list into a data table OR text file? I have looked through the JSL scripting guide and have not come across any functions to convert a list to data table. Any help is appreciated!
pmroz
The scripting index is helpful in this regard.  To set values in a column in a table:
column(dt, "My Column Name") << set values(all_list);
To save a list to a text file:
save text file("c:\temp\myfile.txt", char(all_list));
// To save each entry on its own line:
all_text = concat items(all_list, "
save text file("c:\temp\myfile.txt", all_text);
nnk
nnk
Thanks PMroz....that worked for me!!
