Lino
JSL to Set Graph Y axis Max Value based on Cell Value
I am plotting graph and add refence line. I would like the reference line and Y max axis value can be seen on the graph. I am trying to set the Y axis max value based on the max cell value.
 I do not see the Y max appear in the graph.
Below is my script. Can anyone advise what wrong with the script?
dt= Current Data Table();
MX = Max(:Weight);
If(
	MX < 80,
	    MX = 90;
	    MX = MX + 10
dt << Overlay Plot(
	X( :WW ),
	Y( :Weight ),
	Y Axis[1] << {{Max( MX ), Minor Ticks( 1 ),
	Add Ref Line( 80, "Solid", "Red", "", 1 )}},
	Separate Axes( 1 ),
	Connect Thru Missing( 1 ),
		Dispatch(
			"106",
			ScaleBox,
		Dispatch(
			"101",
			ScaleBox,
			{Min(0), Max( 11 ), Inc( 1 ), Minor Ticks( 1 )}
Re: JSL to Set Graph Y axis Max Value based on Cell Value
The Overlay plot has been depreciated.  One should be using the Graph Builder for this type of graphic.
Here is the script for the graph above
MX = col Max(:Weight);
If(
	MX < 80,
	    MX = 90,
	    MX = MX + 10
gb = dt <<Graph Builder(
	Size( 534, 456 ),
	Variables( X( :WW ), Y( :Weight ) ),
	Elements( Line( X, Y, Legend( 16 ) ), Points( X, Y, Legend( 17 ) ) )
report(gb)[AxisBox(2)] << max(MX) << add ref line( 80, "Solid", "Red", "", 1 );
report(gb)[AxisBox(1)] << min(0) << max(11) << incr(1);
If(
	MX < 80,
	    MX = 90,
	    MX = MX + 10
	Size( 534, 456 ),
Lino
Thanks Jim.
