bernie426
JSL to Reorganize and standardize A Character Column
Hi All,
I wondering is there a clean and easier jsl to manipulate my need.
Let's say having a Character column called "Charge" and there are different input format like "Run #1234", "Run # 1234", "run# 1209", "RUN # 991", this is a issue due to operator input error to the database.
What I want to do is to create a new standardize column with a format of RUN#1234, all cap and no space. It is easy to make to all uppercase by the uppercase jmp script command, but how can I eliminate all different spacing and having them no space in between.
Could any expert show an example script with this request?
Many Thanks,
pmroz
Re: JSL to Reorganize and standardize A Character Column
Add a formula column with the following formula:
Substitute( Uppercase( :Charge ), " ", "" )
pmroz
bernie426
If I write it into a jsl, will it be
Current Data Table()<< New Column("Charge_", Character);
Current Data Table()<< Being Data Update;
For Each Row (
             :Charge_=Substitute( Uppercase( :Charge ), " ", "" );
