JSL statement to turn off and turn on Upper and Lower Limits in Control Chart Builder from a Make Column Switch Handler
I am working on a Community Discussion entry.  My proposed solution uses a Make Column Switch Handler to change the Control Chart Builder display from a standard XBar chart with read in Control Limits, when they are available, to a Run chart with no limits.  The issue is specifically with the turning on and off of the displaying of the control limits.  The functionality exists on the Control Panel, but I have not been able to find a method to change the display/no display programmatically after the chart has been displayed.
Anyone have experience with this?
Re: JSL statement to turn off and turn on Upper and Lower Limits in Control Chart Builder from a Make Column Switch Handler
Do you mean these checkboxes?
I think you might have to go with manipulating the checkboxboxes directly. Below is fairly quick made one, can be made much better
dt = Open("$SAMPLE_DATA/Quality Control/Coating.jmp");
obj = dt << Control Chart Builder(Variables(Y(:Weight), Subgroup(:Sample)));
get_cbs = Expr(
	tbs = Report(obj) << XPath("//TextBox[contains(text(), 'Show Lower Limit') or contains(text(), 'Show Upper') or contains(text(), 'Show Center Line')]");
	mbs = tbs << parent;
	cbs = mbs << sib;
get_cbs;
For(i = 1, i <= N Items(cbs), i++,
	get_cbs;
	cbs[i] << Set(1,0);
get_cbs = Expr(
	cbs = mbs << sib;
get_cbs;
	get_cbs;
	cbs[i] << Set(1,0);
Jarmo,
This is exactly what I need.
Thanks
