JSL script for Graph Builder Save script to data table in JMP15
HI ,
Would anyone be able to advise what is the JSL command to Save Script to Data Table/Journal  in Graph Builder ?
Re: JSL script for Graph Builder Save script to data table in JMP15
Here is an example, taken directly from the Scripting Index
dt = Open( "$SAMPLE_DATA/Grocery Purchases.jmp" );
obj = dt <<
Association Analysis(
	Item( :Product ),
	ID( :Customer ID )
obj <<
Save Script to Data Table(
	"My Analysis", <<Prompt( 0 ), <<Replace( 0 )
