PS_Ato
JSL script - How to create a column with repeating values?
despite looking into many discussions / the scripting index .., I could not get an answer, how to write a JSL script, that will take over the new column command enabling to enter sequence data with N times repetition of each value. I know how to do it manually - thanks to a reply from Mark B... in one of those discussions, but I struggle to write a script
e.g.
N_DOE= 10
N_XRF =4
=> {1,1,1,1,2,2,2,2,3,3,3,3, ...10,10,10,10}
//How may I get a column with repeating values
dt=current data table();
N_DOE=10;
N_XRF=4;
seq = sequence(1,N_DOE,1,N_XRF);
dt << new column("Run", "numeric", "ordinal");
//dt:run << set each value(seq,); // this works, but it is just"1" for all rows
dt:run << set each value(i=1,i<N_DOE,i++, seq);
//dt:run << set each value(for(i=1,i<N_DOE,i++, seq));
//dt << new column("Run", "numeric", "ordinal", values(repeat(seq));
//dt << new column("Run", "numeric", "ordinal", values(repeat(for(i=1,i<N_DOE,i++, seq))));
//dt << new column("Run", "numeric", "ordinal", for each row(for(i=1,i<N_DOE,i++, seq)));
//dt << new column("Run", "numeric", "ordinal", for each row(seq));
Re: JSL script - How to create a column with repeating values?
The Sequence() function really only works within a formula. Take a look at it in the Scripting Index
     Help==>Scripting Index.......Sequence
Here is a working example
names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
N_DOE=10;
N_XRF=4;
// Create the JSL required to set the format and then
// execute it
Eval( Parse(
	"dt:run << set formula( sequence(1, " || char(N_DOE) ||
	", ince = 1, n = " || char(N_XRF) || "));"
N_DOE=10;
N_XRF=4;
// execute it
Eval( Parse(
gzmorgan0
@PS_Ato, Jim, @txnelson  has already provided a solution.
The JMP functions, Sequence() and Count() are very cool functions when working with a data table, since both functions rely on the Row() of the current data table.
There might be times when you want the sequence in just a matrix.  One method is the matrix function  Direct Product(amat, bmat) .  The script below is similar to your original script; it creates seq a vector of repeated values, then assigns them to the new column.
This is provided as an FYI.  If you have not used matrices or studied linear algebra, this would not be the first function that might pop into your mind.
Names Default to Here(1);
N_DOE=10;
N_XRF=4;
New Table("Dummy", add rows(N_DOE * N_XRF));
seq = Transpose(Direct Product(Index(1,N_DOE),J(1,N_XRF,1)));
dt << new column("Run", "numeric", "ordinal", values(seq));
/*  Log output
[1, 1, 1, 1, 2, 2, 2, 2, 3, 3, 3, 3, 4, 4, 4, 4, 5, 5, 5, 5, 6, 6, 6, 6, 7, 7, 7, 7,
8, 8, 8, 8, 9, 9, 9, 9, 10, 10, 10, 10]
