matt7109
JSL: "By Variable" Quantile Median
While JMP does not support a "By Varibale" quanitle, is there any work around?
For example, if I have 2 lists of data, height and age, how would I find the median height of each person of a specific age using JSL.
If I were doing it as a mean, it would look something like (However, I want a median):
Mean( :Height, :Age );
Thanks in advance!!!
Re: JSL: "By Variable" Quantile Median
Select Help > Scripting Index. Now change the first list to show Functions. Select the Statistical group of functions. Select Col Quantile in the second list.
The syntax is Col Quantile( column, probability, <By column> )
matt7109
In the Index, it reads:
Col Quantile
y = Col Quantile ( xCol , p )
This above only finds medan of one variable rather than by column.
When attempthing the syntax you provided (Col Quantile( column, probability, <By column> )),I am recieving a "too many arguements" error.
Thanks!
apparently you are running JMP 12 or earlier.  Here is a formula based upon the Semiconductor Capability sample data table that will do what you want
dt = Current Data Table();
mysite = :SITE;
x = Quantile( 0.5, :NPN1[dt << get rows where( :SITE == mysite )] );
x;
Just replace :Site with your by column, and :NPN1 with your measurement column
You do not have the current version of JMP.
You can seach the discussions here about similar requests and find scripts that solve this problem as a work-around.
matt7109
Ah, I see this is a feature of 13, not 12. Thanks!
