SDF1
JSL: help properly referencing a data table column for Distribution platform
Hi All,
  I'm noticing that the Distribution platform doesn't seem to accept column references in the same way that Graph Builder does, for example.
  I have code where I am referencing different columns within a data table using the Column(dtname, number) format. For example, this is a bit of code where I do it with GB and it works just fine:
Graph Builder(
	Size( 500, 350 ),
	Show Control Panel( 0 ),
	Variables(
		X( Column( dt_results, NNxcol ) ),
		Y( Column( dt_results, NNYCol + N Items( NNXList ) ) ),
		Y( Column( dt_results, NNYCol + 1 + N Items( NNXlist ) ), Position( 1 ) ),
		Y( Column( dt_results, NNYCol + 2 + N Items( NNXList ) ) )
	Elements(
		Position( 1, 1 ),
		Points( X, Y( 1 ), Y( 2 ), Legend( 8 ) ),
		Smoother( X, Y( 1 ), Y( 2 ), Legend( 9 ) )
	Elements( Position( 1, 2 ), Points( X, Y, Legend( 10 ) ), Smoother( X, Y, Legend( 11 ) ) ),
		Dispatch(
			"graph title",
			TextEditBox,
			{Set Text( NNYList[NNYCol] || " Stats vs. " || NNXList[NNxcol] )}
		Dispatch( {}, "Y title", TextEditBox, {Set Text( NNYList[NNYCol] || " Train & Valid" )} )
  However, when I try to do something similar in the Distribution platform, nothing happens, and I think it's because the Continuous Distribution() call doesn't seem to like referencing a column this way. It seems to like referencing the column as Column(column name).
Distribution(
	Continuous Distribution( Column( dt_results, NNYCol + NNcolshift ), Quantiles( 0 ) ),
	Continuous Distribution( Column( dt_results, NNYCol + 1 + NNcolshift ), Quantiles( 0 ) ),
	Continuous Distribution( Column( dt_results, NNYCol + 2 + NNcolshift ), Quantiles( 0 ) )
  I want to use variables when I call the platform because it's more flexible in the code rather than hard-coding in the column name itself. Any idea why the Distribution platform behaves differently or how to correctly reference the column so I get the intended output?
Any thoughts/comments are appreciated.
Thanks!,
DS
hogi
Level XIII
Re: JSL: help properly referencing a data table column for Distribution platform
Or just one of these:
col1 = "height";
col2 = "weight";
Distribution(Continuous Distribution(Column(Eval(col1))));
colList={col1,col2};
Distribution(column(EvalList(colList)));
Further details can be found here:
https://www.pega-analytics.co.uk/blog/handling-lists-of-columns/ (thanks @Ressel :) and here:
https://community.jmp.com/t5/Discussions/Updating-column-list-box-using-list-stored-in-variable-not/...
The confusion arises because (well known) Column is used as a name for a named argument in Continuous Distribution .Many Jmp users will assume that it was the Column() function and use it accordingly.
Same for Data Table() in Col List Box : Updating column list box using list stored in variable not working as expected. Is this how it is me...
mmarchandTSI
Level V
You can just send a message to your data table and remove the table reference in the Column() function.  As for why it doesn't like the syntax of the script that works with Graph Builder, I don't know.
dt_results << Distribution(
	Continuous Distribution( Column( NNYCol + NNcolshift ), Quantiles( 0 ) ),
	Continuous Distribution( Column( NNYCol + 1 + NNcolshift ), Quantiles( 0 ) ),
	Continuous Distribution( Column( NNYCol + 2 + NNcolshift ), Quantiles( 0 ) )
You can use fun and confusing syntax like this
col1 = "height";
col2 = "weight";
dist = dt << Distribution(
	Continuous Distribution(Column(Column(dt, col1)), Quantiles(0)),
	Continuous Distribution(Column(Column(dt, col2)), Quantiles(0))
or this
col1 = "height";
col2 = "weight";
Eval(EvalExpr(
		Continuous Distribution(Column(Eval(col1)), Quantiles(0)),
		Continuous Distribution(Column(Eval(col2)), Quantiles(0))
Edit: Eval(EvalExpr()) is unnecessary in the above script. I left it there by accident when testing out different options (was playing around with Name Expr(AsColumn())).
hogi
Level XIII
col1 = "height";
col2 = "weight";
SDF1
Hi All,
 Thanks for some quick feedback and help on this. I ended up going with a blend of @mmarchandTSI and @jthi 's second suggestion. Unfortunately, the suggestion from @mmarchandTSI didn't end up working by itself, the platform still didn't like the variables for the column number within the Column() reference. However, if I then did an Eval() on the number variables within the Column() reference, then it worked out just fine. So, using Column(Eval()), as @jthi and @hogi did, ended up working as intended.
Thanks for the great suggestions!,
DS
