Chris_Liu
JSL generate map graph
As the attachment, the JPG  graph is manually generated, then save as JSL, when add for loop and use "char(columnname(i))" to place "Flange", it not display "Row Legend()".
manually generated:
Bivariate(
	Y(:Y),
	X(:X),
		Dispatch(
			"Bivar Plot",
			FrameBox,
			{Marker Size(5), Marker Drawing Mode("Normal"),
			Row Legend(
				Flange,
				Color(1),
				Color Theme("Blue to Gray to Red"),
				Marker(0),
				Marker Theme(""),
				Continuous Scale(1),
				Reverse Scale(0),
				Excluded Rows(0)
Re: JSL generate map graph
If you change your JSL line in your attached JSL file from
Char( columnname(i)),
to
Eval( columnname(i)),
your script will work
to
