BHarris
JSL equivalent for "select matching cells"
Is there a JSL equivalent for "select matching cells" in a given column?
For example, I have many simulation runs represented in a single table.  Sometimes I see a rogue data point in Graph Builder, and I want to see all the other points from that run, which is all points with the same "run id".  Is there a way in JSL to select those points, then expand the selection to all rows with the same value in the "run id" column as the points I selected?
14 REPLIES 14
Re: JSL equivalent for "select matching cells"
Here is a script that will do what I think you need
selectionRows = [1, 2, 3, 4];
For( i = 4, i <= 5, i++,
	dt << clear rowstates;
	dt << Select Rows( selectionRows );
	dt << Go To( i );
	dt << Select Matching Cells();
	selectedRows = dt << get selected rows;
	selectedRows = selectedRows[Index( 5, N Rows( selectedRows ) )];
	Column( dt, i )[selectedRows] = .;
dadawasozo
Hi Jim ,
I got error below with the provided. I want to use picture to describe my problem here. please see the next pictures (table) as example. how can I do that with code?
below is my example of the structure of the table. I want to remove empty cell with criteria of only if column2 to column8 are all empty cell. if any of the cell in this range of columns is not empty then do not remove. When I do it with mouse click, I will first (a) highlight first row but only on column2-column8. then I right click to select matching cell (b) and follow with delete (c).
(a)        (b)
(c)
Is this what you are looking for?
dt = New Table( "blood pressure",
	Add Rows( 20 ),
	New Column( "Subject", Set Values( [1, 2, 3, 4, 5, 1, 2, 3, 4, 5, 1, 2, 3, 4, 5, 1, 2, 3, 4, 5] ) ),
	New Column( "S_Dose_Col",
		character,
		"Nominal",
		Set Values(
			{"A", "A", "A", "A", "A", "B", "B", "B", "B", "B", "Control", "Control", "Control", "Control",
			"Control", "Placebo", "Placebo", "Placebo", "Placebo", "Placebo"}
	New Column( "S_BP_8M_Col",
		Numeric,
		Set Values(
			[182.595915155309, 172.512940709438, 180.774421425438, 180.620679187184, ., 171.439595422176,
			174.589230394192, 179.109260746268, 177.787439187438, ., 181.804016028632, ., 186.313144806757,
			175.347853139956, 181.103289178403, 181.288352739913, 178.777832744608, 176.763152449944,
			175.768608854708, 184.167672392284]
	New Column( "S_BP_12M_Col",
		Numeric,
		"Continuous",
		Format( "Fixed Dec", 5, 0 ),
		Set Values(
			[173.550216520736, 180.718560564297, 188.500473854652, 176.718084823659, ., 181.462075626649,
			180.330100756984, 172.886222586229, 192.050244302843, ., 185.501158177984, 183.877324525276,
			179.931613365546, 180.493132509235, 174.944992509985, 177.663853371957, 174.717037207769,
			186.677919707096, 178.12326354079, 171.230704316198]
	New Column( "BP 6M",
		Numeric,
		Set Values(
			[180.116643270986, 180.917546679043, 177.384986937421, 182.381646560932, ., 179.517397097984, .,
			182.904992672503, 176.785646502378, ., 178.209310795898, 186.575178728884, ., 177.2578428812,
			180.642613381863, 178.850703910826, 188.986597488081, 172.45356859494, 182.404679249467,
			182.335148506991]
	New Column( "BP 8W",
		Numeric,
		Set Values(
			[173.797442210887, 170.201828509985, 188.441549950731, 176.337805749776, ., 183.021068043181,
			183.498290114926, 187.881911714776, 184.924564594592, ., 177.186342937671, ., 171.059060559811,
			184.517143208058, 179.143677395064, 178.211632365764, 190.546847185169, 179.666182707754,
			176.614597739946, 181.334797218108]
	New Column( "BP 12W",
		Numeric,
		Set Values(
			[178.416197148117, 178.839136233913, 175.346240386252, 172.773758285362, ., 175.683661608275,
			179.622232533597, 192.773275959188, 172.499108408691, ., 176.573252982367, 174.72327532089,
			172.873089144473, 171.169474537616, 185.445956950321, 181.685844613992, 178.055520662495,
			182.726891244295, 178.320419876662, 186.395858538357]
	New Column( "BP 6W",
		Numeric,
		Set Values(
			[181.152265967985, 176.084997418848, 181.924943930192, 183.608276048664, ., 174.15485890414,
			172.866924129507, 169.793497264777, 179.464417655732, ., 177.20643071091, 176.115218469266,
			181.319863949352, ., 183.622763290159, 178.639264502305, 176.991735583422, 177.924284755616,
			177.143465976767, 183.421182544757]
	New Column( "BP 8F",
		Numeric,
		Set Values(
			[171.278300921568, 175.161843431476, 183.12980493925, 183.04930217403, ., 184.878981656321,
			184.16481869131, 179.098192996471, 186.765084181627, ., 182.640175499696, 179.80577644674,
			179.038752187802, 175.727537977595, 183.636564430071, 188.483289884327, 182.282596238225,
			183.200306257339, 175.856743742269, 183.517577768589]
	New Column( "BP 12F",
		Numeric,
		Set Values(
			[177.570953487335, 184.884491085702, 182.794049100295, 187.31279033708, ., 182.387718653956,
			184.653326274105, 184.653672194875, 184.384583007231, ., 190.972901519754, 181.46178488602,
			181.459302956398, 184.604441269869, 173.249587056935, 183.125809166649, 187.951725739917,
			190.139279669601, 183.549834391574, 171.907000056173]
	New Column( "BP 6F",
		Numeric,
		Set Values(
			[170.514896659448, 187.603078247176, 180.121927541929, 182.931206367403, ., 184.169322994033,
			180.368840760416, 170.403578559484, 177.427685029706, ., 174.986928330607, 184.070139882305,
			189.242086812316, 169.540004898628, 185.21824057543, 173.182049720424, 170.940897197153,
			177.823031925273, 183.621024712236, 178.774574166082]
dt << select where( Is Missing( Sum( dt[Row(), Index( 3, 11 )] ) ) );
dadawasozo
Hi Jim,
This is working. Just one more question for this topic.
what if one of the columns above are mixed data-type with some columns are character and some numeric? How we can select the columns?
Thanks
You will have to add a check for each character column into the Select Where statement.
	Add Rows( 20 ),
		Numeric,
		"Continuous",
		Format( "Best", 10 ),
		Character,
		"Nominal",
		Set Values(
			"Control", "Control", "Control", "Placebo", "Placebo", "Placebo",
		Numeric,
		"Continuous",
		Format( "Best", 16 ),
		Set Values(
			., 171.439595422176, 174.589230394192, 179.109260746268,
			176.763152449944, 175.768608854708, 184.167672392284]
		Numeric,
		"Continuous",
		Set Values(
			., 181.462075626649, 180.330100756984, 172.886222586229,
			174.717037207769, 186.677919707096, 178.12326354079, 171.230704316198]
		Numeric,
		"Continuous",
		Set Values(
			., 179.517397097984, ., 182.904992672503, 176.785646502378, .,
			178.209310795898, 186.575178728884, ., 177.2578428812, 180.642613381863,
			182.335148506991]
		Character,
		"Nominal",
		Set Values(
			{"173.797442210887", "170.201828509985", "188.441549950731",
			"176.337805749776", "Q", "183.021068043181", "183.498290114926",
			"187.881911714776", "184.924564594592", "", "177.186342937671", "",
			"171.059060559811", "184.517143208058", "179.143677395064",
			"178.211632365764", "190.546847185169", "179.666182707754",
			"176.614597739946", "181.334797218108"}
		Numeric,
		"Continuous",
		Set Values(
			., 175.683661608275, 179.622232533597, 192.773275959188,
			172.499108408691, ., 176.573252982367, 174.72327532089, 172.873089144473,
		Numeric,
		"Continuous",
		Set Values(
			., 174.15485890414, 172.866924129507, 169.793497264777, 179.464417655732,
			., 177.20643071091, 176.115218469266, 181.319863949352, .,
		Numeric,
		"Continuous",
		Set Values(
			184.878981656321, 184.16481869131, 179.098192996471, 186.765084181627, .,
			182.640175499696, 179.80577644674, 179.038752187802, 175.727537977595,
			183.636564430071, 188.483289884327, 182.282596238225, 183.200306257339,
		Numeric,
		"Continuous",
		Set Values(
			., 182.387718653956, 184.653326274105, 184.653672194875,
			184.384583007231, ., 190.972901519754, 181.46178488602, 181.459302956398,
		Numeric,
		"Continuous",
		Set Values(
			., 184.169322994033, 180.368840760416, 170.403578559484,
			170.940897197153, 177.823031925273, 183.621024712236, 178.774574166082]
	Add Rows( 20 ),
		character,
		"Nominal",
		Set Values(
		Numeric,
		Set Values(
		Numeric,
		"Continuous",
		Set Values(
		Numeric,
		Set Values(
			182.335148506991]
		Numeric,
		Set Values(
		Numeric,
		Set Values(
		Numeric,
		Set Values(
		Numeric,
		Set Values(
		Numeric,
		Set Values(
		Numeric,
		Set Values(
dt << select where( Is Missing( Sum( dt[Row(), Index( 3, 11 )] ) ) & dt:BP 8W == ""  );
