BHarris
JSL equivalent for "select matching cells"
Is there a JSL equivalent for "select matching cells" in a given column?
For example, I have many simulation runs represented in a single table.  Sometimes I see a rogue data point in Graph Builder, and I want to see all the other points from that run, which is all points with the same "run id".  Is there a way in JSL to select those points, then expand the selection to all rows with the same value in the "run id" column as the points I selected?
3 ACCEPTED SOLUTIONS
gianpaolo
Re: JSL equivalent for "select matching cells"
in JMP --> HELP--> SCRIPTING INDEX  you can find examples..here the ones for 'select where'. hope can help you
dt << Select Where( :Age < 14 );
Gianpaolo Polsinelli
BHarris
I didn't realize when I wrote this that JMP supports setting keyboard shortcuts for menu items.  I set ctrl-shift-m to activate the "select matching cells", and it works perfectly for what I needed.
I assume the responses below would be correct for the original question.
At least JMP16.1 Scripting index provides following:
dt << Select Rows([1, 2, 3, 4]);
dt << Go To(:Height);
Wait(2);
dt << Select Matching Cells();
14 REPLIES 14
GM
GM
You will find JSL examples by searching the Scripting Index with "Select Where".  The examples in the Scripting Index should get you started.  You will need to be able to specify the criteria you are using to identify the rouge data points in graph builder.  Hope this is helpful.
gianpaolo
BHarris
GM
GM
Nice one, that's a cool solution.
Sincerely,
MG
Devin
I see you found the keyboard shortcut - did you ever find a jsl equivalent for ctrl-shift-m, selecting matching cells?  Thx
Wait(2);
dadawasozo
Hi jthi,
I m looking for solution to select first row from column 2 to 193 before the select matching cells.
Do you think you can help?
I am not sure what exactly you are looking for, but maybe this will give you a possible feature you can use.
dt << select where( row() < 24 );
dadawasozo
Hi Jim,
I have 200 columns. what I want to do :
1) select first row across specific set of columns from column 2 to column 193.
2) then apply select matching cell ()
3) last, delete all these matching cells that is across column 2-193.
below will work if I able to make the Go to (Column(2::193)). any suggestion?
Wait(2);
