HansD
JSL: add reference lines to Graph Builder Report depending on value of local data filter
GObj = Graph Builder(
	Size(1221, 652),
	Show Control Panel(0),
	Variables(X(:Date), Y(:Close_s)),
	Elements(Box Plot(X, Y, Legend(5))),
	Local Data Filter(Add Filter(columns(:Date, :Name), Where(:Date >= 01Jun2022), Where(:Name == "Anglo American"))),
		Dispatch(
			"Graph Builder",
			OutlineBox,
			{Set Title("Variability Plot Low Close and High values for the day"), Image Export Display(Normal)}
		Dispatch(
			{}, "Close_s",
			ScaleBox// {Min( 100000 ), Max( 200000 ), Inc( 50000 ), Minor Ticks( 4 )
			// Add Ref Line( 130000, "Solid", "Dark Red", "bought", 1 )}
		Dispatch({}, "graph title", TextEditBox, {Set Text("Low, Close & High against date")})
I would like to add a reference line depending on the :name value in the data filter.
I can programmatically add a reference line and remove the line when needed.  But the reference line must depends on the :name value of the data filter.
I will have a Reference line table with a :Name column and reference line values that I can use to match :Name value in data filter
DateValue = Date MDY(07, 12, 2022);
Report(GObj)[AxisBox(1)] << {Add Ref Line(DateValue, "Solid", "Blue", "Date Bought", 1)};
Report(GObj)[AxisBox(2)] << {Add Ref Line(130000, "Solid", "Green", "Value Bought", 1)};
Re: JSL: add reference lines to Graph Builder Report depending on value of local data filter
If you have reference line table, you could add the reference line column from that to graph builder as Line plot (join or use virtual join to combine data tables).
Example as script:
dt << New Column("RefLine", Numeric, Continuous, << Set Each Value(
	If(:sex == "F",
		50
		60
gb = dt << Graph Builder(
	Size(542, 587),
	Variables(X(:weight), Y(:height), Y(:RefLine, Position(1)), Group X(:sex)),
	Elements(Points(X, Y(1), Legend(3)), Line(Y(2), Legend(7))),
	Local Data Filter(Add Filter(columns(:sex), Where(:sex == "F"))),
		Dispatch({"Points"}, "", OutlineBox, {Close(0)}),
		Dispatch({"Line"}, "", OutlineBox, {Close(0)})
If this won't work other (there are more than two) would be to use Filter Change Handler to trigger the plotting. See Scripting Index for examples
Example as script:
	If(:sex == "F",
		50
		60
	Size(542, 587),
HansD
Hi Jthi, thanks for your fast response and solution - I tried your solutions and it works fine.  I will accept this as a solution.  I will investigate your suggested Filter Change Handler further.  I want to a increase the number of reference lines under certain circumstances.  Regards Hans
