V1N0V3R1T4S
JSL To Change Data Table Script Launch Window Size?
Does anyone know the JSL to change the size of the script-launcher window that's embedded in data tables? The area shown in the pic below, the log doesn't show anything when I adjust the size and I can't find the code that references what this area is:
Re: JSL To Change Data Table Script Launch Window Size?
Here is one option
w_dt = Get Window(dt);
w_dt[SplitterBox(1)] << Set Width(500);
Here is one option
joh13213
Hi Jarmo,
Is there a script that allows changing the height of that window?
I have multiple scripts in a table, but the automatic sizing is hiding some of them.
Manually adjusted height:
You can try to adjust them with << Set Sizes
sb_dt = w_dt[SplitterBox(1)];
Show(sb_dt < get sizes);
wait(1); // demo purposes
w_dt[SplitterBox(1)] << Set Sizes({0.6, 0.3, 0.1})
and you can use << get sizes to get the initial sizing if needed
lala
Level IX
Adjust this post I also asked, but the answer to adjust this height is still not found.
It's OK now.
Pro rata
