terapin
JSL Test for Formula Column Evaluations Done
I'm using JSL to import some data from csv files and to create some new formula columns.  Before proceeding with additional steps, I want to test for whether the new formula columns have completed their evaluations.  Currently, I use the Wait() command but that seems like an unelegant and inefficient way to complete the evaluation.
I've looked in the help manual but can't find a JSL command that allows me to test for whether the Evaluations in my new formula columns have been completed.  Does anyone either know of a command or a method that allows the JSL to wait only as long as is necessary for the formulas to be evaluated before proceeding.  Thanks in advance.
ian_jmp
Level X
Re: JSL Test for Formula Column Evaluations Done
Try something like (from 'Help > Scripting Index'):
dt = Open( "$SAMPLE_DATA/Central Limit Theorem.jmp" );
dt << Add Rows( 100 );
dt << Rerun Formulas;
ian_jmp
Level X
terapin
Thanks Ian,
That was very easy!
dt << run formulas;
