[JSL] Spec limits and reference lines
mosiph
I have been trying to find a script to import specs from specs datatable and set Show Limits( 1 ) for all columns.
I came across a few posts but still could not figure out how to do it.
Please kindly help.
Thanks a lot.
Re: [JSL] Spec limits and reference lines
Here is a simple script that sets spec limits.  It would be a simple matter to place this into a loop that reads from one data table and writes the limits to another, but not knowing the structure of your input table, etc. I am only providing the write component
col="NPN1";
LSL=100;
Target=110;
USL=120;
Eval(
	Eval Expr(
		column(dt,Expr( col )) << set property(
			"spec limits",
			{LSL( Expr( LSL ) ), USL( Expr( USL ) ), Target( Expr( Target ) ), Show Limits( 1 )}
col="NPN1";
LSL=100;
Target=110;
USL=120;
Eval(
	Eval Expr(
			"spec limits",
How many times has this question been posted on the JMP Community? Someone should write a book...  J
Maybe not a book, but it has inspired me enough write some code to add it to the Semiconductor Tool kit
Here is a blog post about checking the box for "Show as graph reference lines".
https://community.jmp.com/t5/Byron-Wingerd-s-Blog/Spec-Limit-Lines-on-Graphs/ba-p/33317
