MathStatChem
JSL Question: How to 'flatten" a list of lists
I would like to convert a "list of lists" e.g.
mylist={{"a","b"}, {"c", "d"}, {"e","f", "g"}}
into a simple list with each element from the nested lists e.g.
// desired outcome is this list
flat_list={"a","b","c","d","e","f","g"}
Is there a simple way to do this in JSL?
In general, the nested lists may also contain lists, and the depth of nesting may not be the same for each element in the starting list, e.g.
wild_list={{"a", {"b", "c"}}, {"d"}, {{"e", {"f"}}, "g"}};
gzmorgan0
Re: JSL Question: How to 'flatten" a list of lists
Attached is a script using charcter functions.  This can also be done with recursion.
gzmorgan0
MathStatChem
Much thanks, very helpful.  I like the recursive function, and I will make use of it.
MathStatChem
With you permission, I'd like to put you script in as a JSL cookbook item.  Let me know if that's ok with you.
gzmorgan0
Sure, go for it.
