pmroz
JSL Programming Challenge: Convert from string of Ys and Ns to matrix of 1s and 0s, and back again
Hi JSL programmers,
I had a little problem as part of a larger application and thought I'd share it with you, and see if there's a way to do it better/slicker.
Basically I have a vector of 1s and 0s (i.e. [1, 1, 0, 0, 1]) that I need to convert to a string of Ys and Ns (i.e. "YYNNY").  Then I need to do the reverse, that is convert a string of Ys and Ns back to a vector of 1s and 0s.
Here are my quick and dirty functions - let's see if you can come up with something beyond my feeble brainpower!
// Convert a vector of 1s and 0s to a string with no separators
matrix_10_to_yn = function({matrix_10}, {default local},
	yn_txt = "";
	if (nrows(matrix_10) > 0,
// Strip out square brackets and commas
		yn_txt = substitute(char(matrix_10), "[", "", "]", "", ", ", "");
// Now convert 1s to Y and 0s to N
		yn_txt = substitute(yn_txt, "1", "Y", "0", "N");
	yn_txt;
// Convert a YN string with no separators to a vector of 1s and 0s
yn_to_matrix_10 = function({yn_txt}, {default local},
	n = length(yn_txt);
	matrix_10 = j(n, 1, 0);
	for (i = 1, i <= n, i++,
		if (substr(yn_txt, i, 1) == "Y",
			matrix_10[i] = 1;
	matrix_10;
// Test thing out a = yn_to_matrix_10("YYYNNNN"); show(a); b = matrix_10_to_yn(a); show(b); c = yn_to_matrix_10(""); show(c); d = matrix_10_to_yn(c); show(d);
5 ACCEPTED SOLUTIONS
gzmorgan0
Re: JSL Programming Challenge: Convert from string of Ys and Ns to matrix of 1s and 0s, and back aga
Whatever works, works!  Here is one alternative.
exmat = J(25,1, RandomInteger(0,1));
exlst = Insert({}, {"Y", "N"}[2-exmat]);
convert_yn = Function({usr}, {rslt, ynList ={"Y","N"} },
 if(IsMatrix(usr),
	rslt = insert({},ynList[2-usr])
 , //else
     rslt = J(nitems(usr),1, 1);
     rslt[loc(usr,"N")]=0
  );  //end if
  rslt
); //end Function
show(exmat, convert_yn(exmat), exlst, convert_yn(exlst));
vince_faller
Another!!
Names Default to here(1);
yto1 = function({str},
	{DEFAULT LOCAL},
	list = words(str, "");
	design(list, {"Y"});
oneToY = function({mat},
	list = substitute(as list(mat), 1, "Y", 0, "N");
	Concat items(list, "");
str = "YYYNNNNYYNY";
nums = yto1(str);
show(nums);
str2 = oneToY(nums);
show(str2, str2==str);
Vince Faller - Predictum
This won't extend to three values or missing/error values without some extra effort. It converts string--blob--matrix and does the Y and N detection using the number of the ASCII character in the matrix. The BlobToMatrix and MatrixToBlob functions are told to use 1-byte little-endian integers. The endianness is not critical for 1-byte numbers, big works just as well. It does depend on the characters having one byte representations.
source = "YYNNYQ";
// if you are uncomfortable with hard coded constants...
Yvalue = Blob To Matrix( Char To Blob( "Y" ), "int", 1, "little" )[1]; // 89
Nvalue = Blob To Matrix( Char To Blob( "N" ), "int", 1, "little" )[1]; // 78
// forward
numbers = Blob To Matrix( Char To Blob( source ), "int", 1, "little" ) == Yvalue;
// reverse
string = Blob To Char( Matrix To Blob( Nvalue + numbers * (Yvalue - Nvalue), "int", 1, "little" ) );
// display
Show( source, numbers, string );
source = "YYNNYQ";
numbers = [1, 1, 0, 0, 1, 0];
string = "YYNNYN";
MathStatChem
you can do the string to matrix conversion in a single line using Char to Blob and Blob to Matrix. My contribution:
names default to here(1);
a=[1,0, 1, 1, 1, 0, 0, 1, 0, 1];
b="YNYYYNNYNY";
f_YNString_to_IndicatorVector=Function({s},
	blob to matrix(char to blob(d),"int", 1, "little", 1)==89;
f_IndicatorVector_to_YNString=Function({v},{vv},
	vv=As List(v);
	vv[loc(v)]="Y";
	vv[loc(!v)]="N";
	concat items(vv,"");
show(a);
show(b);
Show(f_YNString_to_IndicatorVector(b));
Show(f_IndicatorVector_to_YNString(a));
Show(f_IndicatorVector_to_YNString(f_YNString_to_IndicatorVector(b)));
gzmorgan0
These are all very cool solutions. PMROZ pointed out that I misread that the secanrio is to start with a list. He asked for my revised solution.  Below converts a list or a string of YN's to a vector of 10's and a vector of 10's to a string of YN's.
To be consistent with my previous post, I just converted the string to a list with the words() function using an empty string delimiter.
exstr = ConcatItems(Insert({}, {"Y", "N"}[2-exmat]), "");
convert_yn = Function({usr}, {rslt=empty(), ynList ={"Y","N"} },
 if(IsMatrix(usr),
	rslt = ConcatItems(insert({},ynList[2-usr]),"")
 , //else
    IsList(usr),
 , //else
    IsString(usr),
     rslt = J(length(Trim(usr)),1,1);
     rslt[loc(words(usr,""),"N")]=0
  );  //end if
  rslt
); //end Function
show(exmat, convert_yn(exmat), exlst, convert_yn(exlst), exstr, convert_yn(exstr) );
11 REPLIES 11
gzmorgan0
 if(IsMatrix(usr),
 , //else
  );  //end if
  rslt
); //end Function
vince_faller
Another!!
	{DEFAULT LOCAL},
nums = yto1(str);
show(nums);
source = "YYNNYQ";
// forward
// reverse
// display
source = "YYNNYQ";
string = "YYNNYN";
MathStatChem
b="YNYYYNNYNY";
	vv=As List(v);
	vv[loc(v)]="Y";
	vv[loc(!v)]="N";
show(a);
show(b);
MathStatChem
Oops, I didn't see Craig's reply...his version is better, I think.
pmroz
Wow these are amazing.  Thanks all!
and now I need to study the design() function!
uday_guntupalli
Level VIII
@pmroz
         Here is my take/attempt at this. Thanks for offering this interesting challenge. I know I am using a loop which I don't know if it will scale well over large matrices, but I thought, some others in the community can come up with a faster way.
Clear Log(); Clear Globals();
ex = Associative Array({1,0} ,{"Y", "N"});
Test = [1,0, 1, 1, 1, 0, 0, 1, 0, 1];
Res = {};
for(i = 1, i <= N Rows(Test), i++,
		Insert Into(Res, ex << Get Value(Test[i]));
Show(Res);
Best
Uday
ih
Super User (Alumni) ih
I use a generic 'mapply' function in most projects, so normally I would only need the last two lines:
// Utility function to make for loops, combo 'map' and 'apply'
// this is a 'fake' map/apply function because it allows side
// effects (like apply) and it also returns a value (like map)
mapply = function( {x, foo, arg1 = "__missing", arg2 = "__missing"}, { i, r = {}, x, foo, arg1, arg2, arg1missing, arg2missing },
	if( N Items( x ) < 1,
		return({}), //empty list supplied, return an empty list
		for( i = 1, i <= N Items(x), i++,
			arg1missing = 0; arg2missing = 0;
			If( type(arg1) == "String", If( arg1 == "__missing", arg1missing = 1 ) );
			If( type(arg2) == "String", If( arg2 == "__missing", arg2missing = 1 ) );
			if(
				arg1missing == 1,
				r = Insert( r, foo( x[i] ) ),
				arg2missing == 1,
				r = Insert( r, foo( x[i], arg1 ) ),
				r = Insert( r, foo( x[i], arg1, arg2 ) )
	return(r);
// Solution:
(numbers = mapply( words(str,""), function( {x}, if( x=="Y", 1, 0) ) ) )
mapply( as list(numbers), function( {x}, if( x==1,"Y", "N") ) )
