Stokes
JSL: How to add graph to an existing window
Hi, I am using JSL to plot with graph builder.
Every graph usally created in a seperate window which opens too many window.
I want to put each graph into the same window then close the new created window.
Below are my draft jsl, can anyone help me to make it work?
Thank you.
WW1 = New Window( "graph1", Graph Builder() );
Window( "graph1" ) << Close Window();
WW2 = New Window( "graph2", Graph Builder() );
Window( "graph2" ) << Close Window();
WW3 = New Window( "graph3", Graph Builder() );
Window( "graph3" ) << Close Window();
Re: JSL: How to add graph to an existing window
Take a look at this example.  It creates one window with 20 graphs defined for it, with no additional graphs being created
dt = Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
nw = New Window( "graphs", myvlb = V List Box() );
colNamesList = dt << get column names( continuous, string );
For( i = 1, i <= 20, i++,
	myvlb << append( oneway( x( :site ), y( Column( colNamesList[i] ) ) ) )
Stokes
Thank you for the help.
I will try to put this with my scripts.
7 REPLIES 7
Here are two ways to have multiple outputs in one window.  There are other ways too
names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
nw=new window("Example 1",
	bivariate(x(:height), y(:weight)),
	oneway(x(:sex),y(:weight))
nw2=new window("Example 2");
nw2<<append(bivariate(x(:height), y(:weight)));
nw2<<append(oneway(x(:sex),y(:weight)));
Craige_Hales
The journal window might be a solution as well. Send the <<journal command to the windows before you close them. The journal window keeps a tall list of the entries.
Craige
Stokes
I used journal before, but journal will freeze the graph, meaning I can not select the the data in the graph anymore, it is more like a picture.
Thank you.
Stokes
Thanks for the solution, for some reason it doesn't work in my script.
Can you help to modify based on my script below?
I am ploting over 200 graph which can only be done with graph builder.
So I hope to add the graph to a same window graph, then close the graph builder window after ploting.
Otherwise, I end up open 200 windows.
Stokes
ron_horne
Hi @Stokes ,
@txnelson and @Craige_Hales gave good examples. another way to do it is to start with just one window. if you have a data table open, try using this script. once you make the graphs you want in that window you can save the script from the plot.
New window ("lots of graphs",
	v list box (
		Graph Builder(),
		Graph Builder(),
		Graph Builder(),
		Graph Builder(),
		Graph Builder(),
		Graph Builder(),
