worldkeeping
JSL: How to Save Simulation Formula of the best fitted distribution in a new table?
The procedure I hope to achieve is
1) fit all distributions to a column
2) use "Save Simulation Formula" of the best fitted distribution
3) but instead of "Save Simulation Formula" to the original table, I want to save it to a new table with 10 rows. This means the saved formula will generate 10 values from that best fitted distribution in this new table.
The challenge I have now is
1) when using Fit Distribution('All'), the Fit Handle[] can't find any specific distribution. I was hoping Fit Handle[1] will give me the best fit.
2) I am not sure how to let "Save Simulation Formula"  to save to a non-original table.
Please help me.
worldkeeping
Re: JSL: How to Save Simulation Formula of the best fitted distribution in a new table?
Solved by fitting fixed set of distribution instead of fit all.
The second challenge solved by just get formula from original table and create a new table with it
worldkeeping
Hi @worldkeeping ,
I'm looking into a similar challenge, could you provide more detail for the process you used?
Thanks,
Ben
