chris_dennis
JSL Error collecting data through interactive Modal Window.
I am trying to use a modal window in a script.  The window is intended to display a window with some text information, a graph, and ask the user to enter some information by Yes/No questions.  User results will be stored in a data table and information will be stored for latter reference in a Journal.  I receive the following error when the "Cancel" button is pressed: at line 443 in development 3.jsl  There is no response to the modal window when the "Submit" Button is pressed,  I expect the window to close.
I would appreciate any help or suggestions you might be able to provide.  My development script is attached for reference.
Re: JSL Error collecting data through interactive Modal Window.
I think you might have attached incorrect file or at least the project is missing the script file.
