fat_angus
JSL Creating a New Column from Components in another Column Character Scripting
Suppose I have input column  and want to create a new column based it's contents. The input column will always have a total of 8 slashes like below. However, sometimes there will be actual data of varying lengths between them. Thus... I want to indicate in a new column when there is data with a simple 'Y' and all other places would be 'N' over a large number of rows.
Input Column                  Desired_Output
////////                                NNNNNNNNN
////////                                NNNNNNNNN
////a/b///                            NNNNYYNNN
a////////                              YNNNNNNNN
Georg
Re: JSL Creating a New Column from Components in another Column Character Scripting
Howewer, to return 8 characters in each case you may use another formula, see formula2 in that table:
New Table( "Test 3",
	Add Rows( 4 ),
	New Column( "Input Column",
		Character,
		"Nominal",
		Set Values( {"////////", "////////", "////aaaa/b///", "aBCD////////"} )
	New Column( "Formula",
		Character,
		"Nominal",
		Formula(
			Regex(
				Regex(
					Regex( :Input Column, "[a-z]+", "A", GLOBALREPLACE, IGNORECASE ),
					"Y",
					GLOBALREPLACE
				"N",
				GLOBALREPLACE
		Set Display Width( 246 )
	New Column( "Formula2",
		Character,
		"None",
		Formula(
			item_lst = Words( Substitute( :Input Column, "/", "/;" ), ";" );
			result_str = "";
			For( i = 1, i <= N Items( item_lst ), i++,
				If( item_lst[i] == "/",
					result_str = result_str || "N",
					result_str = result_str || "Y"
			result_str;
		Set Selected,
		Set Display Width( 394 )
Georg
You could use double regex in a formula:
Regex(Regex(:Input Column, "[^/]", "Y", GLOBALREPLACE), "/", "N", GLOBALREPLACE)
One regex to replace everything that isn't "/" with "Y" and other to replace "/" with "N".
fat_angus
Thanks for the reply. Wasn't familiar with this function and it is useful/helpful. This takes care of the slashes but gives me a 'Y' for every letter in the string. I only want one 'Y' for all characters between the slashes.
Georg
You can add just another regex, that replaces many characters by one:
dt = New Table( "Test",
	Add Rows( 4 ),
	New Column( "Input Column", Character, "Nominal", Set Values( {"////////", "////////", "////aaaa/b///", "aBCD////////"} ) ),
		Character,
		"Nominal",
		Formula( Regex( Regex( Regex( :Input Column, "[a-z]+", "A", GLOBALREPLACE, IGNORECASE ), "[^/]", "Y", GLOBALREPLACE ), "/", "N", GLOBALREPLACE ) ),
		Set Selected,
Georg
Georg
	Add Rows( 4 ),
		Character,
		"Nominal",
		Character,
		"Nominal",
		Formula(
			Regex(
				Regex(
					"Y",
					GLOBALREPLACE
				"N",
				GLOBALREPLACE
		Character,
		"None",
		Formula(
			result_str = "";
			result_str;
		Set Selected,
Georg
fat_angus
Very big thank you! And to all others that helped. The Formula2 nailed it.
