jj200812
JMP17 interactive html working with Save As but can;t re-create in code only
I have successfully made an interactive html report when doing the File -> SaveAs method, however, I'm having issues getting the interactive html to show the data filters when saving in jsl code. Can someone take a look and see if I'm missing something obvious here?
Here is the code I'm using:
JMP17
v2 = dtconcat << Graph Builder(
	Size(951, 734),
	Show Control Panel(0),
	Variables(X(:TIME), Y(:Something), Overlay(:label)),
	Elements(Points(X, Y, Legend(11)), Smoother(X, Y, Legend(12))),
	Local Data Filter(
		Show Modes(1),
		Count Excluded Rows(0),
		Mode(Include(0)),
		Add Filter(
			columns(:label, :"otherlabel"n),
			Display(:label, N Items(15), Find(Set Text(""))),
			Display(:"otherlabel"n, N Items(5))
v2 << save interactive html("path\path1\path2\test.html");
Re: JMP17 interactive html working with Save As but can;t re-create in code only
You might have to wrap it to new window first or take higher level reference to capture also filter
dt = open("$SAMPLE_DATA/Big Class.jmp");
nw = New Window("Graph Builder",
	gb = dt << Graph Builder(
		Size(525, 454),
		Variables(X(:weight), Y(:height), Overlay(:sex)),
		Elements(Points(X, Y, Legend(9)), Line Of Fit(X, Y, Legend(11))),
		Local Data Filter(
			Show Modes(1),
			Mode(Include(0)),
			Add Filter(columns(:age), Display(:age, N Items(6)))
nw << Save Interactive HTML("$TEMP/test.html");
nw << Close Window;
Web("$TEMP/test.html");
With higher (or rather highest in this case) level reference
	Size(525, 454),
	Local Data Filter(
		Show Modes(1),
		Mode(Include(0)),
topref = (gb << top parent);
topref << Save Interactive HTML("$TEMP/test.html");
		Size(525, 454),
		Local Data Filter(
			Show Modes(1),
			Mode(Include(0)),
nw << Close Window;
	Size(525, 454),
	Local Data Filter(
		Show Modes(1),
		Mode(Include(0)),
jj200812
Thanks Jarmo! I also found this previous post which captures your idea. It works now!
Solved: Missing Local Data Filter in "Save Interactive HTML()" Script - JMP User Community
