AdamChoen
JMP17 Vs 14 interactive HTML differences
Hello community,
not sure if this is a JMP issue but I'll try to get insights anyway.
In my HTML dashboard code, I link some interactive html files created in JSL.
for some reason when I started using JMP17 (Vs 14) the files are not uploading anymore thru my dashboard (loading forever) but works fine if I just opens them in my browser....
I apricate your inputs on JMP17 Vs 14 interactive HTML differences that may be related to start TSing the issue.
Adam.
Thanks, Adam
Re: JMP17 Vs 14 interactive HTML differences
Generally I would say Developer tools in your browser is the starting place for this type of issues.
But JMP17 did have some change (not sure what), JMP16 and JMP18 saved files work if I remember correctly. Issue is most likely with some some sort of cross origin requests and modern browsers (there are restrictions in place).
