JMP16: Life Distribution Platform Default Distribution
Created:
Mar 3, 2023 10:00 AM
| Last Modified: Jun 8, 2023 9:31 AM(1821 views)
I am using the Life Distribution Platform > Compare Groups tab. I have the continuous variable in the Y then categorical variables in the Grouping & By fields. So several distributions are generated. The default distribution is Nonparametric. Is there a way to change the default distribution to Weibull within the platform without scripting? I need to manually click the Weibull radio button for each distribution generated. I checked under File > Preferences > Platforms > Life Distribution but I am not seeing that option available there. is it somewhere else or not possible? I like the ability, after changing all to Weibull distributions, to be able to Make Combined Data Table for the Weibull Parametric Estimates.
