Pearl
JMP scripting - Double FOR loop: H List Box and V List Box
Hi everyone,
I started to learn scripting and I'm trying to do a Window with 6 scatteplot: 2 vertical + 3 horizontal.
I've tried a double for loop but I don't know why it doesn't work. It gives no error but I cannot get the images.The code is:
BladeList = List( "Blade8", "Blade61", "Blade74" );
New Window( "Oneway Advisor",
	H List Box(
		For( j = 1, j <= 2, j++,
			V List Box(
				For( i = 1, i <= 3, i++,
					Write(i);
					Scatterplot 3D(
						Y( :Name( " x" ), :y, :z ),
						Coloring( :Name( " Mean Io" ) ),
						Legend( 1522 ),
						Frame3D(
							Legend( 1 ),
							Set Grab Handles( 0 ),
							Set Rotation( -64, 0, -41 ),
							Set Marker Scale( 5.2652 )
						Where( :Blade == BladeList[i] & :Embodiment == "THP" ),
							Dispatch(
								"100",
								ScaleBox,
								{Legend Model(
									1522,
									Properties(
										0,
										{gradient( {Color Theme( "Jet" )} )},
										Item ID( " Mean Io", 1 )
However if I try a single loop it works:
	H List Box(
		/*For( j = 1, j <= 2, j++,*/
			V List Box(
					Write(i);
					Scatterplot 3D(
						Legend( 1522 ),
						Frame3D(
							Legend( 1 ),
							Dispatch(
								"100",
								ScaleBox,
								{Legend Model(
									1522,
									Properties(
										0,
						V List Box(
					Write(i);
					Scatterplot 3D(
						Legend( 1522 ),
						Frame3D(
							Legend( 1 ),
							Dispatch(
								"100",
								ScaleBox,
								{Legend Model(
									1522,
									Properties(
										0,
Can anyone help me with this.
Thank you,
David
Re: JMP scripting - Double FOR loop: H List Box and V List Box
I was not able to get the double loop to work, however, the below method will get you he results you want
	hlb = H List Box()
	vlb = V List Box(
			sc = Scatterplot 3D(
				invisible,
				Legend( 1522 ),
				Frame3D(
					Legend( 1 ),
					Dispatch(
						"100",
						ScaleBox,
						{Legend Model(
							1522,
							Properties( 0, {gradient( {Color Theme( "Jet" )} )}, Item ID( " Mean Io", 1 ) )
	hlb << append( vlb );
	hlb = H List Box()
	vlb = V List Box(
				invisible,
				Legend( 1522 ),
				Frame3D(
					Legend( 1 ),
					Dispatch(
						"100",
						ScaleBox,
						{Legend Model(
							1522,
Pearl
Thank you very much txnelson for your help! It works perfectly.
Evan_Morris
I know this is a bit of an old thread to bring back, but I can't tell what was the fundamental change between the two sets of code that fixed the nested loop issue. I'm getting an error in one of my tools using a nested loop, I'm hoping it is related.
Edit:  Is it just a matter of using that HLB append functionality?
