jinsejoseph
JMP script to find max value from mutiple column with unique key word
Hi Team,
I am looking for a script that can help to find max value from mutiple column ,
but column count will vary run to run but will have a unique key word as test_result,
Thanks in advance
Test_Result 1Test_Result 2Test_Result 3Test_Result 4Test_Result 5Test_Result 6Test_Result 7Test_Result 8Expected data
-58151      151
110111      111
111110      111
111111      111
111110      111
110110      110
111110      111
108108108107109109110113113
109111108110110110110110111
Re: JMP script to find max value from mutiple column with unique key word
If you want to have formula, here is one slight modification you could do:
Eval(Parse("dt << new column(\!"max_col\!",numeric,formula( Maximum(" || ":" || Concat Items(use_cols, ", :") || ")));"));
jinsejoseph
Hi , Tried below command,
Eval(Parse("dt << new column(\!"max_col\!",numeric,formula( Maximum(" || char(use_cols) || ")));"));
were use_cols having the column name,
but not able to find max value,
when checked formula found that " " is appending in MAXIMUM function,
 how to remove the " "
jinsejoseph
Hi Jthi,
Thanks a lot, you suggestion help to solve the issue
