zjuv007
JMP script for entering in variable text?
Hi all,
Is there a command/way for JMP to ask you to input certain parameters/strings/values (e.g. file location, file name, etc.) via a pop-up box while I run a script?
1. Ask the user to input the file location (Is there a way for it to work like a simple 'Open' function does in any program where you can go directly to the folder?)
2. Wait until the user has performed #1.
3. Perform the rest of the script once the above actions have taken place.
I'm trying to automate a way to have over 100 excel files with different names, and figured the best solution would be to ask the user to input the actual file name/location to standardize a bit. Fortunately, the column structure is the same throughout.
Kind Regards,
Zach
ian_jmp
Level X
Re: JMP script for entering in variable text?
To get you started, try 'Help > Scripting Index' and serach for 'PickDirectory()','PickFile()' and 'FilesInDirectory()'.
ian_jmp
Level X
