hwchoi0109
JMP script for a user select Y, response columns for Fit Y by X
I'm trying to write a script that user can select columns for 'Y, response', 'X, Factor', and 'By' for Fit Y by X or Bivariate.
I figured out that I can use 'Column Dialog' function to select Y, X, and By using below script. But, I could not write a script to plot Fit Y by X with selected columns. It would be really appreciated if anyone can help to make a full script.
Thanks in advance.
Regards,
Hyungwoo
colDlg = Column Dialog(
Title( "Column Selection" ),
ycol = Col List( "Y, Response", Min Col( 1 ) ),
xcol = Col List( "X, Factor", Min Col( 1 ) ),
bycol = Col List ( "By", Min Col(1))
Re: JMP script for a user select Y, response columns for Fit Y by X
This should get you forward:
dt = Open("$SAMPLE_DATA/Consumer Preferences.jmp");
Show(colDlg);
biv = dt << Bivariate(Y(colDlg["ycol"]), X(colDlg["xcol"]), By(colDlg["bycol"]));
