vishwasanj
Level V
JMP recovery files pop-up window CLOSE
Hi All,
I am trying to run everything in the background and trying to have no windows open. By any chance is there a way to close the JMP recovery files window which pops up when I start running the files suggesting me to save anything that has not been saved properly with the previous run?
Thanks.
ih
Super User (Alumni) ih
Re: JMP recovery files pop-up window CLOSE
If this task is something you run on a scheduler you could use a bat file similar to what @msharp describes here.  I do something simialr and have not had trouble with popup windows yet.
