JMP importing change since 18 upgrade
My scripts that I made before using the "Open" command is JSL is now way too slow. My script takes 12 minutes to execute now.
How should I import excel sheets now or please fix this but in JMP
I used to import my excel files using this code below but it takes too long:
Open(
"/Z:/Shared/R&D/Runsheet.xlsx",
Worksheets(
{"Thickness"}
Use for all sheets( 1 ),
Concatenate Worksheets( 1 ),
Worksheet Settings(
1,
Has Column Headers( 1 ),
Headers Start on Row( 2 ),
Data Starts on Row( 3 ),
Data Starts on Column( 1 ),
Data Ends on Row( 0 ),
Data Ends on Column( 33 ),
Replicated Spanned Rows( 1 ),
Suppress Hidden Rows( 1 ),
Suppress Hidden Columns( 1 ),
Suppress Empty Columns( 1 ),
Treat as Hierarchy( 0 ),
Multiple Series Stack( 0 ),
Import Cell Colors( 0 ),
Limit Column Detect( 0 ),
dt1 = Current Data Table();
dt1 << Set Name( "Thickness");
// I do this for a few different tables and then combine the tables together using the code below. What is taking so long to run this code?
Data Table( "Thickness" ) << Join(
With( Data Table( "dt2" ) ),
Merge Same Name Columns,
Match Flag( 0 ),
By Matching Columns( :Run # = :Run #),
Drop multiples( 0, 0 ),
Include Nonmatches( 1, 1 ),
Preserve main table order( 1 ),
Output Table( "OutputTable" )
Byron_JMP
Re: JMP importing change since 18 upgrade
I've been using the same open for Excel and haven't noticed any changes. I'm opening about 100 files and concatinating them.   If you move/copy your excel files to your computer (local drive)  and then run the script is it still slow?
Yup, I just tried that and I have the same long delay (11 min instead of 12 this time) when I moved it to the C:\drive\.
I then tried to see if the problem is the importing of the table or the joining of the tables by importing just one table (or more specifically one worksheet of one excel file), and it still took 3 min which is better, but still way longer than it used to using JMP 17.
The table does have 2k rows and 33 columns. Is there a faster way to import large tables?
Did your 100 files contain large tables?
Level XII
Once I had a speed issue when importing an excel file.
I found out that some cells were combined. removing such cells increased the speed by several orders of magnitude:
TS - 00129314.
Do you have combined cells in Excel?
datanorm
Just upgraded from JMP 17 to JMP 18 today, same issue as you. Opening an xlsm file of 100k rows and 100 columns used to take 60 seconds in JMP 17, in JMP 18 it ran for hours without finishing opening the file. I had to use task manager to force close JMP.... Please help us JMP.
datanorm
@txnelson any ideas what's different in JMP 18 that causes this? There is another thread with this same issue, and i just see you always having good answers everywhere else
Are you using JMP 18.1?  This was fixed in that release.  The underlying library that is used to read Excel files was changed between JMP 17 and 18, and for merge cells there was a performance issue. Of course, JMP 18.2 will also contain this fix when it is released.
Brian Corcoran
JMP Development
